Why not make it bigger?
So, I drained and refilled my clutch fluid for the first time (38k miles) It was nasty..
After 4 drains and refills I thought to myself...why not make the reservoir bigger...the added volume will help reduce fluid temps and it will be a lot easier to swap out.
As far as making it easier to change, you're just going to have more dirty fluid to change out with a bigger reservoir so it'll just take longer.
I upped the resivoir on my car- increases the amount of pressure you can use when Mighty Vac bleeding, as well as amount of pressure you can put out and not have the system fall victim to itself ( kill the seals on the slave from the pressure from the master ) - And it makes the fluid changes from the top much easier due to inceased volume. There are some space restraints but its nothing that cant be over come.
