vibration
Old Oct 4, 2008 | 08:26 PM
ElkySS's Avatar
Default vibration
my driveshaft will not stop vibrating. it got an ls1 driveshaft, i just had it balanced with new u-joints, all rear bushings are new except sway bar (and they are pretty shot) new torque arm bushing. im thinking my torque arm might be twisted or bent. anyone else got any other ideas?
Old Oct 5, 2008 | 09:05 AM
ElkySS's Avatar
no one?
Old Oct 5, 2008 | 09:44 AM
99wssixm6's Avatar
Pinion bearing, Trans output bearing?
Old Oct 6, 2008 | 07:47 AM
calhoon's Avatar
Was the reason for the new shaft due to the orig getting broken/ damaged? If so you may have a bent trans mainshaft. Also check for a cracked bell.
Old Oct 6, 2008 | 09:37 AM
ElkySS's Avatar
no the old one was the infamous LT1 vibshaft. so i replace the steel one with the aluminum one. i just had the bell housing off and it looked ok. ill check the bearings in a couple weeks when i set my pinion depth again.
