Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Moser 12 bolt rearend
Old Feb 21, 2009 | 07:03 AM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
Thumbs up Moser 12 bolt rearend
Making some changes to the car, wanted to just change gears and go to 5/8 drive studs but my brother has me thinking M9. Not sure what will go in but this is coming out.....so here it is:
- Moser 12 bolt narrowed 1 1/4" each side(narrowed 2.5" total)
- 4.30 gear on aluminum spool(Eaton posi also comes with it and is set up for 3 channel ABS)-spool not set up for ABS
- 33 spline axles, gun drilled, with 1/2" wheel studs(3" long)
- Lower control relocation brackets welded on
- 1350 series yoke
- Performance Moser rear cover
Rearend has 500 miles on it, 55 passes with the Eaton posi, and 12 passes with the spool. New axle and carrier bearings were installed when the spool went in. Also throwing in a Spohn rear sway bar with poly bushings and end links. Rearend is still in car, you can view pics of it on the build link in my sig. Brakes do not come with the rear, but it is set up for factory brakes. Would prefer not to ship, for pick up only. $1900.00 cash or if paying by credit card add $57 for our 3% credit card fee(not our fee, the credit merchant services).
Jon
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
