Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
F.a.s.t 92 help
Old Mar 12, 2010 | 12:03 AM
amoureyls1's Avatar
Default F.a.s.t 92 help
alright i just got my intake manifold and i replaced the bolts is the valley cover and now i need to know do i need to remover the steam pipe on top of the cover or what ever its real name is..... can i get some feed back guy
Old Mar 12, 2010 | 09:26 AM
t/a for life's Avatar
YOU BUSTED MY FRIEND HAHAHA, but bump for a friend anyone help him at all??
Old Mar 12, 2010 | 01:05 PM
Ryan33187's Avatar
No, You do not remove that pipe... you keep it there, but what year is your car? If it is 01+ then the intake manifold should fit fine if it is 00- then you might have to modify it a bit so the manifold fits flush.
Old Mar 12, 2010 | 01:30 PM
LT1Formula007's Avatar
I have the LS6 steam pipes on my car. They come factory on the 01-02 cars. I think they run about $50 new. They will insure you have NO clearance issues. Also when I did my FAST 92 they only sent 9 or 10 bolts and there are actually 10 or 11 bolts. Watch out and make sure you replace the proper bolts and leave the 1 there. If not you can crack the intake when you bolt it down. I'll post pics if you need me to. lmk.
James
Old Mar 12, 2010 | 03:40 PM
amoureyls1's Avatar
i have a 99 and i have 10 bolts on the valley cover and i got them all replaced but what i am having problems with is fast is saying i have to take that off and replace with a GM part number so idk what the deal is i am trying to get some pic so yea man if u have some post them for me that would help out a lot
Old Mar 12, 2010 | 07:33 PM
Here is a picture of my engine with the LS6 Steam tube in the front, and the rear just use plugs that come with the kit. I don't have any pics of the rear, but basically if you cut the tube off at the part where it bolts to the head on each side, thats the only part you'll need for both sides in the rear. BUT they are completely closed off. And the front is just like you see.... It goes from the left head to the right head and has a port for the hose to connect to for your TB/Radiator bleed off port. If you have any more questions, Please PM me or I'll look back here in this thread.... And if you get on some of the sponsors websites, you'll prolly find what you need. Thunder Racing or Speed Inc. usually carry some good stuff. Also SDPC will carry them too.
James
