Every little bit counts
I suppose you first have to ignore the documented small differences in LS1's from year to year (cam profiles, injectors, tunes, availability of emissions equipment and their weight, intakes, etc..) and then you have to forget about vehicle options and manufacturing variations (that ultimately affect engine output) and then also assume a bunch more things like the type of rear diff fluid, tire pressure, down to even the health of the motor mounts... after all that, the cars will be so close that a change in any one of those things can swing it either way. That's what I meant by insignificant. Plus you have to ask yourself if you're comparing T-Top cars, which models (for the hoods & wings), i
With that said, I'd say that the firebird has a measurably less aerodynamic body and loses in the end even if you tack on the "ram air" effect of a WS6. Which one weighs less given identical options, body type, and year (eg 2002 t-top)?
