Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Help! Autometer Hook Up!
Old May 10, 2006 | 11:03 AM
BlackBirdWs6Zzz's Avatar
Default Help! Autometer Hook Up!
Ok I have a 5" tach. I need to know where you guys hooked up the power and where you hooked up the ground. I have a LT1, which wire to I tap in for the RPM's.
I need to know a 12v power source that isn't on 24/7, just something that comes on with the ignition or light switch!
NEED RECOMMENDATIONS QUICKLY THANKS
!Josh
ANY PICTURES OR WRITE UPS WOULD BE GREAT! MAYBE EVEN A SCAN OF THE DIRECTIONS TO HOOK UP! I bought it used!
Old May 10, 2006 | 11:27 AM
88monte's Avatar
liqour enthusiest
!Josh
i hooked mine up to the ignition switch. post in the electrical section on tech because i dont know if the lt1 and ls1 have the same fuseable links.
Old May 10, 2006 | 11:34 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
https://ls1tech.com/forums/lt1-lt4-modifications/504685-autometer-hook-up-help-please.html
