FS:1994 Formula
Engine - 396 Storker Motor
- Eagle 3.8750 stroke crank
- Eagle 6.00" rods
- The block is bored .030 over
- Has splayed 4 bolt main caps
- All arp main bolts and head bolts
- .236/.245 .575/.595 Custom Ground Cam (112 LSA)
- 58MM BBK Throttle Body
- Ported Heads (I have the Flow Sheet)
- Accel Optispark
- Taylor 8MM Wires
- NGK Plugs
- Brand New Coil (2 days old
)- 36 LBS Injectors
- New GM Oil Pump
- A/C Delete
- SLP Fan Switch
- SLP Elbow
- Morso CAI
- New Alty and Battery
- New Refab Duralast Starter
- Dnyatech Lontubes into a 3 inch Y-pipe over axle dual SLP Slash Tips (no cats)
- Polyuthren Engine Mounts
- Emissions are GONE
THe car has had regular Oil Changes of 1,500 miles with Royal Purple 10w - 30
motor was dnyotuned at Slingshot Motorsports in Fox River Grove,IL
Car dnyoed at 418HP and 467TQ
Also, have been down to the track many times and have many time slips to prove how fast it is. The last pass with this car was 7-13-07 and ran 11.72 @ 119MPH and .60ft a 1.51
Tranmission - 4L60E (Freshly Redone)
- 2800 Vigilante Stall
- TCI Flexplate
- Brand New Bands, Clutch packs, and just flushed with Royal Purple Trans Fluid
- Transpack Shift Kit
Rear End - 10 Bolt - 3:73 Richmond Gear
- Eaton Posi
- Upgraded Axles
Suspension - Almost Complete- BMR Sub-frame Connectors
- BMR Lower Control Arms
- BMR Panhand Bar
- EdleBrock Torque Arm
- Eibach Front Drag Springs
- Energy Suspension Trans Mount
- New Polyuthren Rear End Bushing
Misc
- Warbird Hood
- LS1 Tail Lights
- Matching Blue vnyle (bird Fill-in, Pontaic Fill-in etc....)
- Limo Tint All around
PICS
The body of the car has no rust. It did have a problem in the shop and has a small crack on the passanger fender, the arm on the lift it what caused it. Other then that there are no Imperfections in the body at all. I can also post a pic of the crack upon request.
Im asking $11,000 o.b.o
will sell out of state but must be in midwest, also will CONSIDED TRADE FOR SEMI MODDED LS1
Night at RSD@GLD 7-13-07
^^^ most recent pic ^^^
