Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Scanners
Old Apr 30, 2008 | 10:37 AM
jjenkins's Avatar
Default Scanners
What is the a good brand of scanner to purchase, would like to stay around $200 if possible. Also what would be the stock convertor stall speed in an A4 trans? J
Old May 1, 2008 | 02:36 AM
GreenBlood's Avatar
stock stall i believe is somewhere in the 1600-1800 range...If i stall my car up at a light, it holds at 1600 before the tires finally break loose...
Old May 1, 2008 | 04:53 AM
koolaid_kid's Avatar
Correct.
AFA scanners, probably need a little more information. Do you just want a basic hand-held? Do you want to be able to clear DTCs? Do you want to be able to log data? Do you want a software/firmware PC or Palm Pilot based one?
Old May 2, 2008 | 02:19 PM
jjenkins's Avatar
Default scanner
I do not need to log the info., but I do want to be able to clear codes and be able to maximize the performance of the car.
