Any tips on cleaning polished/chrome?
got any pics of the problems? if you are having a hard time getting into crevices, I would take a variable speed dremel type tool, put a little baby buff on it and run it in those areas at the lowest speed setting. that'll work ok unless its really some bad corrosion/dirt then you're not going to get very far with re sanding the metal and re polishing it. if the chrome is damaged beyond cleaning off surface corrosion, it would need to be re plated.
