Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Need stall tuned in Nebraska!!
Old Sep 15, 2008 | 07:35 PM
blakern's Avatar
Default Need stall tuned in Nebraska!!
Like it says I need help. I recently installed a vig 3200 stall and I have lockup issues. Car wont stay lockedup on the hiway. Its constantly locking and unlocking, and then sometimes when your slowing down it wont unlock as soon as it should. All when the AC is on it tends to stay lockedup more then when the AC is off. Is there anyone out here that has the software and know-how to tune this for me. I got my dyno tune @ dynosport in Lincoln NE and he did a great job, but I took it to him after the converter install and thought he got it fixed but its still acting up. You know how that goes, you take your car to the shop and as soon as you get there it stops acting up, and on the way home it starts back up again.
Im not blaming dynosport at all for not getting it fixed, but is there anyone here that can help. Im really sure its in the tune. Anyone in nebraska had a converter tuned before? Where did you go? Who tuned it?
Old Sep 15, 2008 | 09:51 PM
Hell'sChariot's Avatar
I had my car tuned at dynosport with no problems. I have an ss4000. You can try cs motorsports here in omaha. Contact Tom at 402-896-8199. They are just off Hwy 370 and I-80 at 11308 S 152nd Omaha.
Old Sep 16, 2008 | 01:27 AM
mvvette97's Avatar
I would think if it was the tune then it would do it all the time. If I could see the tune I could tell you if that was the problem. If I wasn't 2hrs away I would hook it up to my efi live and maybe figure it out.
Old Nov 18, 2008 | 11:14 AM
blakern's Avatar
bump.
Still having this problem. Found a guy that has HP tuners in my area. Anyone know what to do to correct this?
Please help.
Old Nov 19, 2008 | 11:06 AM
wait4me's Avatar
You need to modify the missfire tables, set the min tcc pressure up a bit and a few other things to fix pressures..
Old Nov 19, 2008 | 04:48 PM
blakern's Avatar
thanks for the reply wait4me. ive read that you can just max out the values in the missfire tables, is this correct? Are there any negatives from maxing out the missfire tables?
Thanks again.
Old Nov 24, 2008 | 06:58 PM
blakern's Avatar
Problem fixed. Changed all the misfire values to 32767
Special thanks to (blazin)......
