Military Hotrod Club For our members in the Armed Forces
Class B setup??? Help Needed
Old Sep 25, 2012 | 09:51 PM
Z28Dave's Avatar
Default Class B setup??? Help Needed
Alright well apart from being informed last minute i got pretty much a day to set up My Class B uniform for inspection for "payday activities"
Does anyone have the measurements for the Short sleeve shirt? I have Army greens.
Old Sep 27, 2012 | 12:24 PM
roy's Avatar
roy
Huh!!!
Army greens???
Is that uniform still authorized for wear ?
Old Sep 27, 2012 | 12:48 PM
bones_c's Avatar
It should only take you like ten minutes... All the same as on the jacket except if your junior then put rank on the collar one inch from the point of the collar or if your nco put your shoulder boards on... Your uniform should always be set up and ready to go at all times... Take it to the cleaner and when you pick it up first thing to do is put it ncm together so that when **** like your talking about happens you don't have to worry because you know your good to go!!! Step it up man!!!
Old Sep 27, 2012 | 07:39 PM
Z28Dave's Avatar
Originally Posted by roy
Huh!!!
Army greens???
Haha yes yes it is still authorized to wear, since now that they are thinking of ditching the ASUs. Class As might be standard issue again
and i was able to slap on everything no problem with good merriments all around
