First 9 second pass for me!
. I need to get the logs checked out, and I already have a converter lined up if this one is slipping. Then I can just get the restall done and sell it. After running your weight and trap speed through a calculator, it seems you're only puttin down around 680 to the tire right now. Get that converter checked out.
. The Best V8 Stories One Small Block at Time
You're missing a ton of mph. I hope you get the converter issues worked out (or whatever the problem is).
