Under the curve power?
Old Apr 18, 2010 | 06:33 PM
Nitroused383's Avatar
Default Under the curve power?
I was out doing a little tuning and decided to video this. Let's see what you guys got. I think mysetup has pretty fat torque band for a 346 with unported heads and small cam. 3.42 gears in 4th gear.
50-60 = 1.71 seconds (2300-2800 rpm)
60-70 = 1.562 (2800-3250)
70-80 = 1.576 (3250-3680)
80-90 = 1.962 (3680-4180) 3 degree's knock retard @ 4000 rpm doh!
90-100 = 1.735 (4180-4640)
100-110 = 1.665 (4640-5100)
110-120 = 1.636 (5100-5550)
120-130 = 2.137 (5550-6000)
130-140 = 2.73 (6000-6450)
All in all pretty linear acceleration I would say, and as you can how big of a factor wind resistance becomes above 120 mph.
http://www.youtube.com/watch?v=Z2flc_dwVuo
Old Apr 18, 2010 | 07:25 PM
zlicious94's Avatar
Thats some serious angle of the dangle **** man. Car pulls hard though!
Old Apr 18, 2010 | 07:56 PM
I gained a lot going from an LS6 intake to a ported 85mm Fast I did and installing an underdrive pulley. The car pulls so much better and looking at old logs I have picked up quite a bit. Should be over 430rwhp / 400 tq no problem now. Not bad for unported 243's and a custom 224 cam
Old Apr 18, 2010 | 07:57 PM
BrianC98Z28's Avatar
your SES light is on
Old Apr 18, 2010 | 07:58 PM
blkjck's Avatar
Staging Troll
very nice, 45-140 in one gear haha hows the traction in 1st, 2nd, 3rd?
Old Apr 18, 2010 | 09:07 PM
Correct, Open loop speed density with maf delete. MAF failure set to Mil on 1st error reported. I suppose I can shut the light off, since I know it's in SD, but I have not done so yet.
It's not the greatest, 275/40-17 Nexen tires. Will blow them off if I hammer it in 1st at 2500 rpm and if I shift hard into 2nd the car goes sideways laying rubber up to 70 mph. My Midwest Chassis 9" with 4.11's will be in shortly, I will post more vids with the 4.11's. Traction will be a lot worse but now I won't have to worry about destroying the 10 bolt at the track with slicks.
Also with the cutout open I gain 17 hp / 13 tq and it was closed on that video. Here is a little burnout with cutout open when I had the LS6 intake.
http://www.youtube.com/watch?v=CYIqTCqFy7U
Old Apr 18, 2010 | 10:03 PM
nick122590's Avatar
nice pickup, that burnout was sick lol
Old Apr 25, 2010 | 05:06 PM
Anyone else care to post a video with a 4th gear punch and 3.42s? 408s, prochargers, turbo come on I want to see the difference.
Old Apr 25, 2010 | 05:18 PM
Spd-Kilz's Avatar
I'll post up a video with 3.73 with HCI for you soon
I love the burnout!
Old Apr 25, 2010 | 07:39 PM
DiscerningZ32's Avatar
I remember that burnout video. That vid is great.
Old Apr 26, 2010 | 04:51 PM
SilverSS's Avatar
I have to upload the crappy video somehow. No 3.42's though.
M6, 347, d1sc, 4.10's, 700rwhp. 4th gear 70-110mph in about 3.8 secs.
Old Apr 27, 2010 | 06:57 PM
Gauge's Avatar
11Second Club
Be sure you factor in the fact that as you increase speed, the resistance against the car increases exponentially. So, while your 50-60 and 110-120 times may be very similar, your car is doing a LOT more work in the same amount of time at the higher speed. In short, this isn't a very scientific test.
Old Apr 28, 2010 | 04:42 AM
Yes I do understand that. This was far from a scientific test, more of a comparison with other similar geared cars. Apparently no one wants to post up the acceleration of there setups (under the curve, below 5000 rpm).
Old Apr 28, 2010 | 10:01 AM
blkjck's Avatar
Staging Troll
that burnout was sick..the best my car can do is light smokin the passanger front tire till 30 haha
Old May 2, 2010 | 03:43 AM
Well guys I have confirmed my suspicions of my "power under the curve". 365 rwtq @ 3000 rpm, thats 30 ft lbs more than my bolt on car made at peak torque! 414 max torque now
Check here for more info https://ls1tech.com/forums/dynamomet...nderdrive.html
