tt wagon at the dyno
dans boost sensor reads a little higher than the map sensor in the car so i will post both boost numbers. boost is a little slow to come on and creeps at the top. john needs to hook the electronic boost controller back up and see if that helps. i think it will.
12psi/11psi = 609hp. this is the every day driving on the wg spring power.
14psi/13psi = 690hp
16psi/15psi = 750hp
19.5/18psi = 800hp
i put it on youtube >> http://youtu.be/KCzusdf7bkA
also put it on my server which should be higher quality but sometimes doesn't work. >> http://neufamily.org/vids/novadyno.wmv
