first startup and test drive
Old Sep 10, 2012 | 08:55 AM
rumblebox's Avatar
Default first startup and test drive
i put LS3 heads on my LQ4 with .040 gaskets and a 226/231 .600.600 114 comp cam. i also had my street fighter 3500 rebuilt to factory specs. from what i can tell, it's a great converter for the money.
1st startup
1st test drive
after a 2 mile cruise and a bath
it runs amazingly considering the fact that i havent changed the IFR tables for bigger injectors... havent even hooked the laptop up to it yet!
Old Sep 10, 2012 | 10:41 AM
chadroosa's Avatar
sounds good...nice work
Old Sep 10, 2012 | 10:52 AM
thunderstruck507's Avatar
I'm sure you know but be very careful how much you let it run with the wrong tables in there for the injectors. From every source I've read even just starting it is a big no no.
Old Sep 10, 2012 | 10:55 AM
rumblebox's Avatar
going from 26.4# to 36# was pretty bad before i changed the IFR, but this was from 36 to 39. i'll probably change it before i drive it again just to be safe.
