dyno vids
Old Sep 18, 2005 | 07:48 PM
RDTA's Avatar
Default dyno vids
this was from a dynoday we had yesterday my turd has a magicstick,ud pulley, headers,duels with dynatech splitflow muffs. it made 368/372 with a unlocked pt4400, I wasnt real happy but it was also 80 degrees in that shop to, and a street tune of 12.2 on the wide band,28deg timing and the lightning was a buddy of mine it is a stock long block with a precision 76mmturbo and stock air to water intercooler, I think it made 640/713 on 16# http://video.ls1tech.com/Player.aspx...2-19F95C1532B8 http://video.ls1tech.com/Player.aspx...3-1A44D73F8E3A
Old Sep 18, 2005 | 08:27 PM
SRfastZ's Avatar
just a question but what does that mean unlocked or lock ? what is the different ?
Old Sep 18, 2005 | 08:51 PM
RDTA's Avatar
well you know the converters have lock up clutches in them you can manually lock them up with HP tuners or something like that and it will make more power on the dyno but in real life the converter is unlocked at wot and is slipping. that is why a M6 will usually dyno higher than a A4 becouse the slipping converter is not very eff. thus the lower #'s
Old Sep 18, 2005 | 08:52 PM
RDTA's Avatar
well you know the converters have lock up clutches in them you can manually lock them up with HP tuners or something like that and it will make more power on the dyno but in real life the converter is unlocked at wot and is slipping. that is why a M6 will usually dyno higher than a A4 becouse the slipping converter is not very eff. thus the lower #'s (oops hit the button twice)
Old Sep 22, 2005 | 07:14 PM
SRfastZ's Avatar
thanks for the info.
