OK, Need Some Help
Diagrams are needed the most
lt1's have a shorter stroke and larger bore, most of its power is at a much lower rpm than an ls1, they can be made damn fast but not necessarliy the same way an ls1 can be made damn fast. weak points: shitty *** ingition system until 95??? (opti-spark) heavier (iron block) strong points: good tire roasting torque from the bottom of the tach
ls1's have the juice up top, longer stroke smaller bore, again can be made damn fast but not necessarliy the same way an lt1 would. strong points: 4000rpm-6000rpm, individual coil packs, lighter (aluminum block) weak points: err. . . jk pushrods
iv never owned or even worked on an lt1, all the info above is merely **** i have ramdomly picked up, so im sure some of it is wrong, dont flame me for it, just correct me.
