Quad turbo Camaro
Old Apr 30, 2006 | 10:01 AM
7sechemi's Avatar
for 4 turbo's I'm not too overly impressed, only 25 pounds of boost, they can get that out of 1 turbo thats not even all that big, they could have saved themselves a bunch of time by just plopin a supercharger on top, 2100 respectible but I've seen much more out of regualr old doorslammers
Old Apr 30, 2006 | 10:15 AM
grandsport96's Avatar
the work is insane, to bad they never got numbers out of it...
Old Apr 30, 2006 | 01:21 PM
njn63's Avatar
you guys need to remember that 25psi on a single turbo probably wouldn't be the same amount of CFM as 25psi on those 4. The size of the turbo is also important, not just the pressure.
Old Apr 30, 2006 | 01:29 PM
Iroc313's Avatar
wow thats alota heat was this made before the ME412 I always thought chrysler came up with it
Old Apr 30, 2006 | 02:23 PM
FASTASS_LS1's Avatar
That thing looks like a monster. Its gonna brake a few dyno's and lay down some impressive numbers thats for sure.
Old Apr 30, 2006 | 02:47 PM
NumberOneSled's Avatar
Originally Posted by StreetKing
It was outlawed at all sanctioned races (NSCA, PRO etc) because everyone was crying about single or twin turbos and no one had ever written rules for a quad turbo. The motor/car was a huge disappointment. They were allowed to run at Orlando at the World Street Finals and only made one pass. It shook the tires real hard so they aborted the run, the second pass it dropped a valve. I dont think they ever tried it again with the quad turbos. I think they later on sold the motor to Mike Bowman in California, put twins on it and he had alot of succes with it.
That's exactly what happened.
Old Apr 30, 2006 | 02:58 PM
ELMiN8oR's Avatar
4 turbo`s
Is there any video`s for this "Monster" ??
Old May 2, 2006 | 08:29 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by VerySlowTA
Very cool looking engine, especially the intake manifold. It seems like a huge waste though. Why would you use 4 turbos to make 25 lbs of boost? Just to say you did?
While difficult to discern it seems the turbos are placed sequentially. This allows one turbo usually smaller to spool a larger turbo after the first one develops boost. This is the sort of turbo system found stock on twin turbo supras and RX7 s. It allows quicker boost response by spooling the smaller turbo for low end grunt then using the boost of the smaller turbo to spool the larger one for higher rpm power. When you're using large turbos like that camaro is it seems like it would work quite well.
I'm impressed by the HP and Torque numbers, but dissapointed that they never got any full runs out of it. If you spent alll that money and time developing that thing I'm sure you'd spend the little bit of extra money to fix it to get at least one run out of it and see what all that work was worth.
Old May 2, 2006 | 08:31 PM
camaroextra's Avatar
Are you serious? Those are parallel turbos, not sequential, if they were sequential, there would only be 1 down pipe on each side. each turbo is running off of 2 cylinders
Old May 2, 2006 | 08:51 PM
OWN3D BY MY PROF!
Sorry about that. Disregard former post.
no problemo
Old May 2, 2006 | 10:01 PM
  #32
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
That is one huge A$$ motor
Old May 2, 2006 | 10:31 PM
  #33
273sunsetZ's Avatar
It's the most beautiful thing I've ever seen.
Old May 3, 2006 | 01:16 AM
  #34
THE_SUPRA's Avatar
yeah i had one of thoes it was ok
Old May 3, 2006 | 02:43 PM
  #35
tboysen00's Avatar
thats what im talking about
Old May 3, 2006 | 03:46 PM
  #36
WRX-ERROR's Avatar
PSI is pretty much meaning less, 20psi on a 16g is not the same as 20psi on a gt35. It's all about CFM. Believe me when I tell you those 4 turbos at 25PSI are pushing a TON more CFM then most turboed cars.
In any case.. Thats a whole lot of piping.. I love it..
Old May 3, 2006 | 03:52 PM
  #37
CRAGER's Avatar
Administrator
Thats badass!
Old May 3, 2006 | 04:11 PM
  #38
cmanz28's Avatar
Wow I have never seen anything like that...simply amazing!
Old May 7, 2006 | 12:22 PM
  #39
Gold Phoenix's Avatar
I don't know if you guys noticed, but that is the chassis and body that W2W used for their first 6-second LS1 motor.
