Photoshop request thread
I am needing the top blue/gray put over the dark gray box in the middle. I am trying to make it transparent, so basically just need the blue/gray body lines in the middle box.
The bottom picture is the full edited color shot just in case you cannot work with the grayscaled bottom photo.
Everything should line up with the bottom right corners. Thanks again!
Hows that?
I think its going to look cool
I'm getting starting on the right side now. It's going to be harder to mount the projectors than I thought. Nothing that a little thought/fabricating won't fix.
I'm hard pressed right now to fiberglass my own housing/base... or modify the C6 one. If I use the C6 one, the lights are pretty close together. Then where the 3rd DRL light is, (I deleted) I'll round up with the same angle as the front bumper and into the fender. That's the best way I can come up with the make the lights look less close together.
I'm also smoking/tinting the clear covers. Any way you could give me a slightly tinted look? That's just going to be the icing on the cake IMO, it should look bad as hell.
Thanks for your time, I appreciate it!
Rob
back wheels couldnt get right
heres a try at a sig type thing of course gotta make smaller though
i know u already posted mcheap, and no offense, but yours seemed "dark" to me and the other one lacked "detail" in the background.
and here is another sig. the other was too big
the 2nd one you posted is on top, mine is on bottom. look at the car. no offense
yours
mine
[/IMG]
