F1 nuts
Old Jan 13, 2007 | 11:55 AM
JUICED96Z
Guest
Posts: n/a
Default F1 nuts
Amazing what stupid amounts of money can do. You can even sing god save the queen with revs lol
http://www.youtube.com/watch?v=1JPBdBIFGNQ
Check out the fuel spray on this one
http://www.youtube.com/watch?v=o_QyUD6V5_I
CRAZY header heat and more singing at the end lol
http://www.youtube.com/watch?v=_-ouB...elated&search=
Old Jan 13, 2007 | 12:01 PM
lewroe's Avatar
amazing.
Old Jan 13, 2007 | 12:16 PM
kozak's Avatar
one of the best things i did this summer was go to italy for a month. the next best thing was going to the ferrari store in milan. awesome.
Old Jan 13, 2007 | 02:32 PM
Runn's Avatar
There is no engine in the world that compares to a Formula 1 engine...
Old Jan 13, 2007 | 02:36 PM
Wnts2Go10O's Avatar
how about the outlawed turbine motor that almost won the indy 500?
Old Jan 13, 2007 | 02:42 PM
Runn's Avatar
You mean back in 1967... yes thats a nice piece too.
I think the regulation of the F1 engines is to hard but.... http://en.wikipedia.org/wiki/List_of...la_One_engines
Engine
Formula One engines must be naturally aspirated, four-stroke internal combustion petrol engines with reciprocating circular pistons and a maximum of two intake and two exhaust valves per cylinder. They must be V8 engines and have 2.4 liters of displacement.
The rules between 2000 and 2005[1][2] stated that Formula One engines may be no more than 3 litres engine displacement and must have 10 cylinders. In order to curb increasing power levels, the maximum engine displacement has been reduced to 2.4 litres, and the number of cylinders to 8 for 2006. However, a concession is made in the rules to allow some teams the option of running 10 cylinder 3.0l engines for 2006. This rule is intended to help poorer teams unable to produce an engine and chassis to comply fully with the new regulations in time for the 2006 season. All teams using the 10 cylinder 3.0l engines will be subject to a rev limiter to decrease power.
Devices designed to pre-cool air before it enters the cylinders are not allowed, nor is the injection of any substance into the cylinders other than air and (petrol) fuel.
Variable-length intake and exhaust systems are also forbidden.
The crankshaft and camshafts must be made of steel or cast iron. The use of carbon composite materials for the cylinder block, cylinder head and pistons is not allowed.
Separate starting devices may be used to start engines in the pits and on the grid. If the engine is fitted with an anti-stall device, this must be set to cut the engine within ten seconds in the event of an accident.
Old Jan 13, 2007 | 03:01 PM
LS1AC-Cobra's Avatar
wish my LS1 would rev up like this when I hit the pedal...
http://www.youtube.com/watch?v=DMqg-...elated&search=
Old Jan 13, 2007 | 03:05 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Nothing greater than F1 IMO.
Old Jan 13, 2007 | 03:47 PM
skifast87's Avatar
some on explane to me how that sec vid worked. The one where i could see the fuel spraying.
Old Jan 14, 2007 | 04:17 PM
JUICED96Z
Guest
Posts: n/a
RPM's are so high that is sucks the ful right in is my guess.
