Dyno runs
Old Feb 3, 2007 | 07:12 AM
2001z's Avatar
Default Dyno runs
I thought i would just thought i would share a couple vids from yesterday. Stock heads and cam with 27*of timing going through my new 9in rear with 4.11s i put down 346hp 367tq and on spray with 750psi bottle pressure 490hp 641tq. I believe i would have hit the 500 mark with 950 bottle pressure !! Sorry if the vids are crappy .
Old Feb 3, 2007 | 08:25 AM
TORCHD 02 TA's Avatar
can't hear ****
Old Feb 3, 2007 | 08:30 AM
SpaZMaN's Avatar
i can hear it
Old Feb 3, 2007 | 01:05 PM
2001z's Avatar
I also just checked the weather report and ther ewas 100% humidity yesterday in rutherfordton where i dynoed yesterday So it has some left in it !!!
Old Feb 3, 2007 | 01:12 PM
'Trust''s Avatar
Car sounds good, what setup do you have? Any internal work?
Old Feb 3, 2007 | 01:42 PM
2001z's Avatar
coated Pacesetter headers, ory,magnaflow bullet, ported throttlebody,lid,9in with 4.11s,pro 5.0, spec stage 3 clutch, Bmr adjustable LCAs ,weldin subframe connectors,BMR adkustable pahnardbar,ported maf,velocity stack,Racetronix kit plus hotwire kit, and nitrous with most of the goodies just missing the progressive controler. Stock heads and cam!!! That is next .
Old Feb 3, 2007 | 04:51 PM
2001z's Avatar
Here is the dyno graphs i forgot to grab the last one where we had the a/f at 12.8 at its peak during spray and kept about the same numbers. Even at 100%humidity and about 45 degrees.
Old Feb 3, 2007 | 06:02 PM
wow you car was quiet, i could not hear at my computer at work.. at home i could hear it a little better...
Another question, did the guy make the pull with the car in 3rd gear?
Old Feb 3, 2007 | 06:16 PM
2001z's Avatar
No i was the driver and that is in 4thgear. It must be the camera i used becouse my car is pretty loud lol sometimes it is annoying on the highway but its a sports car not a grocery getter!!
Old Feb 3, 2007 | 09:11 PM
ahhh jsut checking in the first vid, you musta shifted right onto 2nd right away and i thought that it was 1st....
Must be the camera lol..
Old Feb 4, 2007 | 06:53 AM
2001z's Avatar
Ya my wife was taking the vid so she might have started it to late . The vid was being taken with a digital camera so quality and sound isnt the best ! The guy who was supposed to bring the real camera couldnt make it becouse someone broke into one of his houses !!
Old Feb 4, 2007 | 08:28 AM
unit213's Avatar
Administrator
A/F is not looking good on the sauce. Are you going to spray it like that?
Old Feb 4, 2007 | 09:41 AM
2001z's Avatar
Ya that one is a little high i didnt grab the last sheet at the dyno where it is 12.8 peak but kept the same power level matter of fact it was a little more on the top . You should have seen how high it was at first i had to shut her down when it spiked to 17.1 So my tuner worked on 3300-4600 and fatened it up some to get it from that high peak i wish i would have grabed that sheet it ws the pull right after the one on the thread.
Old Feb 7, 2007 | 04:57 PM
2001z's Avatar
Actually i watched it again it it goes through all the gears to 4th
