Is this real?
Old Mar 12, 2007 | 04:31 PM
Sluggish's Avatar
Default Is this real?
damn he has a big chin
jay leno bike
Old Mar 12, 2007 | 06:04 PM
djsanchez2's Avatar
Most deff. is!! It is a mini jet out of a helicopter from what i heard. That thing would smash on the dodge tomahawk!!
Old Mar 12, 2007 | 07:15 PM
White 96LT1's Avatar
Yup! its called a Y2K bike. i sat on one before
Old Mar 13, 2007 | 06:38 AM
97'RS6-BucketTurd's Avatar
http://www.marineturbine.com/motorsports.asp is the site.
Specs:
Engine:
Rolls Royce Allison
250 series gas turbine
Power
320 HP @52,000 rpm
(286 HP @ rear wheel)
Torque:
425 ft/lbs @ 2,000 rpm
Output RPM:
6,000 rpm
Compressor Speed:
54,000 rpm
Weight:
500 lbs
Frame:
aluminum alloy
Fairings:
carbon fiber
Rake:
27 degrees
Seat Height:
31.5 in
Wheel Base:
68 in
Wheels:
17" carbon fiber, Dymag
Tires - Front:
120 60ZR17, Pirelli
- Rear:
200 50ZR17, Pirelli
Brakes:
3x320 mm floating system- 4 piston
calipers, Brembo
Shocks:
mono-shock adjustable
oleopneumatic, Ohlins
Front Forks:
55 mm inverted
Fuel:
diesel, kerosene
Fuel Capacity:
8.5 gallons (34 liters)
Lubrication:
dry-sump/3.5 quarts turbine oil
Transmission:
2 speed automatic
Rear View:
rear mounted camera with LCD color
display plus side mirrors
Seat:
single or double
Colors:
infinite custom colors
The Designer and builder of that bike (the y2k bike) also had a hand in building this one although it was designed by another person:
AKIRA flashbacks anyone?
More pics/info on that bike here:http://www.timcamerondesign.com.au/dream.htm
Old Mar 13, 2007 | 12:13 PM
MrDavid's Avatar
^^ That bike is hidious
