HUGE motor (pics and info)
Total engine weight: 2300 tons (The crankshaft alone weighs 300 tons.)
Length: 89 feet
Height: 44 feet
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm (5 million ft/lbs!)
Only have pics of the 10 cylinder version though
Main journals are 16" wide
Notice there is are little ladders leading down into the crankcase.
Piston and rod
Got head studs?
J.
LOL Think it will fit! LOL ...you too funny.
http://www.pureluckdesign.com/other/rta96c/
Fuel consumption at maximum power is 0.278 lbs per hp per hour (Brake Specific Fuel Consumption). Fuel consumption at maximum economy is 0.260 lbs/hp/hour. At maximum economy the engine exceeds 50% thermal efficiency. That is, more than 50% of the energy in the fuel in converted to motion.
For comparison, most automotive and small aircraft engines have BSFC figures in the 0.40-0.60 lbs/hp/hr range and 25-30% thermal efficiency range.
this engine get cubic inches (1820 liters) and produces 7780 horsepower
I'd like to see those numbers on a 10,000 shot
