Hell Raisor
Old Dec 16, 2007 | 06:00 PM
Dynotune04's Avatar
Default Hell Raisor
04 Mystic Chrome saleen cobra
stock longblock
eaton blower with stock pulley
hellion hellraisor kit
http://vidsearch.myspace.com/index.c...deoid=23913453
Old Dec 16, 2007 | 06:19 PM
CAMAROZ28AQUINO's Avatar
wow
Old Dec 16, 2007 | 06:27 PM
LS1SpeedAddict's Avatar
does the stock long block have forged anything?
Old Dec 16, 2007 | 06:28 PM
Dynotune04's Avatar
a stock 03/04 cobra longblock already has a forged crank rods and pistons with a very boost friendly 8:5:1 compression ratio
Old Dec 16, 2007 | 07:27 PM
Spoolin's Avatar
WOW!! Man that is an incredible car!! I wonder how long she'll last at that hp level! Any more specs on it? What kinda boost is she seeing with the blower?
Old Dec 16, 2007 | 08:03 PM
krly79's Avatar
Did you notice that it is roots supercharged AND Twin Turbo charged? That thing is a monster.
Old Dec 17, 2007 | 04:16 AM
Mr. Bungle's Avatar
That was no stock pulley on the eaton. It was a Billet Flow pulley. Do know what size? Great numbers.
Old Dec 17, 2007 | 08:40 AM
Dynotune04's Avatar
my bad wrong specs for that car. thats a ported eaton with a pulley. its not a stock pulley but its larger than 3". smaller pulleys have not worked as well with the setup thus far
 Michael S. Palmer
Old Dec 17, 2007 | 10:55 AM
Spoolin's Avatar
Hard to see the twins from the camera's angle as I'm sure if it is in fact a compound system the twins are remote mount or rear mounted of some type. Couple things I could and couldn't pick up on is I could hear the turbo's for a short second as it was loading up but when they let off I didn't hear a blow off valve. I also didn't hear the typical compressor whine. Having that said they could of re-routed the BOV back into the exhaust and masked the S/C whine.
Only thing I that I could see is the odd intake tubing coming from from the right wheel well and it's blurry but I don't visually see a BOV either. In any case I'm wondering if there's a build up thread running around because that would be one of the first street compound system's that I'm aware of other than VW's unique designs.
Also if it is a twins/blower that intake tube is coming from an odd place assuming that the charge piping from the twins is passing through a front mount intercooler first.
Edit: I do hear some BOV chatter as he's moving up through the gears.
Old Dec 17, 2007 | 03:48 PM
Dynotune04's Avatar
its a compound boost set up twin 57's blowing into the roots. front mount intercooler sits behind the factory heat exchanger. turbos are mounted behind the bumper cover. similar to the hp twins set up.
Old Dec 17, 2007 | 03:56 PM
armkneez8's Avatar
That's alot of HP's
Old Dec 17, 2007 | 04:37 PM
blck89rs's Avatar
what he said, there was an issue in fastfordsmusclemustangs this month with a basically stock termy with the EXACT same setup laying down something like 1035rwhp/1003 ftlbs, its crazy
Old Dec 17, 2007 | 07:52 PM
Spoolin's Avatar
http://www.musclemustangfastfords.co...bra/index.html
Old Dec 17, 2007 | 09:52 PM
krly79's Avatar
Beat me to it
