In Need of MAJOR Help!!
Old Oct 20, 2008 | 09:51 PM
BoostJunkieXL's Avatar
Default In Need of MAJOR Help!!
I just bought a 00 T/A WS6 today. I drove it around for most of the day with no problems. Then all of a sudden it falls flat on it face. No power. It acts like its not getting fuel. Smells very lean. I ran the codes and it said that all the O2's are lean and the mass air flow is messing up. Someone tell me what the problem could be. Or atleast point me in the right direction. THANKS!
Old Oct 20, 2008 | 09:58 PM
conan's Avatar
Check your fuel pressure. Might be loosing the pump. Pull a few plugs and see if there white... = lean. Also did you get any maf codes?
Old Oct 20, 2008 | 10:11 PM
It did throw a MAF code. It said something about MAF sensor circuit malfunction/performance low. I believe thats what it said.
Old Oct 20, 2008 | 10:18 PM
conan's Avatar
If the maf isn't reading right it will controll the amount of fuel your moter recieves. Have any buddys with a f body you swap the maf to see if your problems clear up? Also do you have a K/N filter? reason i ask is it could have been over oiled and got in the maf. You can try cleaning the maf too.
Old Oct 20, 2008 | 10:23 PM
Thanks for the help! I've only owned this car for about 10 hours so I'm sure you can understand my worries. But I really appreciate the help!
Old Oct 20, 2008 | 10:36 PM
conan's Avatar
Its cool... just resist the temptation to drive it untill you get it figured out. If you do have to drive it be very gentle. Lean= HOT and will self destruct. Also did you check to see if its got a K/N air filter?
Old Oct 20, 2008 | 11:12 PM
bamxbam's Avatar
I'd clean/replace the air filter if it's dirty, and then check the MAF to see if it's clean, get a can of CRC MAF cleaner and see if cleaning it works. I never had a problem with the car falling on its face, and the MAF on my car wasn't really dirty, but cleaning it anyway seems to have made it run stronger and get better gas mileage.
Old Oct 21, 2008 | 11:27 AM
foreverzero's Avatar
How many miles are on the car? .....sounds like somebody over oiled their filter, make sure you give it a good tune-up and a good seafoam treatment after you fixed the problem
Old Oct 21, 2008 | 09:11 PM
It was the gasket around the air lid. Half of it was gone and it was sucking air in. Thanks for all the help guys! Its people like you that make joining these forums worth it!
Old Oct 21, 2008 | 09:54 PM
99bluefirebird's Avatar
Gasket around the air lid wouldn't have an effect, since its before the MAF and throttle body.
