Exhaust Question
Old Oct 24, 2008 | 11:23 AM
DownSouthWS6's Avatar
Default Exhaust Question
im about to put a full exhaust on and im gonna go catless. should i cut off the O2 sensor thats after the cat to prevent having the service engine soon light on constantly?
Old Oct 24, 2008 | 11:57 AM
conan's Avatar
Leave the wires and have the rear o2's tuned out of the computer.
Old Oct 26, 2008 | 01:46 PM
NTIMD8's Avatar
You can also get an O2 sim to trick your car into thinking it still has the cats in place.
Old Oct 26, 2008 | 10:05 PM
where the hell do i get an O2 sim? im guessing sim stands for simulator.
Old Oct 26, 2008 | 10:23 PM
bobbyd's Avatar
i thinks ws6store.com has them
yup sim = simulator
Old Oct 27, 2008 | 12:11 PM
SOMbitch's Avatar
Just tune them out.
Old Oct 27, 2008 | 10:32 PM
wildbird02's Avatar
I agree. Tune them out. A tune really smooths out that power curve too.
Old Oct 27, 2008 | 11:23 PM
OMGls1jz's Avatar
when my bro put on his LTs he eliminated his two back o2 sensors with some connector that went from the front ones to the back ones i think, but i'm not completely sure. maybe some one can shed some more light on this
Old Oct 28, 2008 | 09:16 AM
now im confused. are we talkin bout just a normal engine tune that also gets rid of the sensors or a tune that solely tunes them out?
Old Oct 28, 2008 | 09:40 AM
teke184's Avatar
you can do either
some places will only charge you $25 or so to tune JUST the sensors out.
but if you're gonna do full exhaust, getting a full dyno or street tune will optimize your power and allow changing of things like fan settings, shift points, torque management, skip shift, EGR, AIR....etc...
and cutting the wires off is the same as just disconnecting the sensors...you'll still get the code.
but the code has NOTHING to do with the operating condition of the car/computer.
Old Oct 28, 2008 | 10:15 AM
OMGls1jz's Avatar
when the code does come on, will that hurt the daily driving any and will it consume more gas?
Old Oct 28, 2008 | 10:20 AM
do those $350 hyperchip programmer things do the same thing as a shop would do?
Old Oct 28, 2008 | 02:08 PM
SonicBoom's Avatar
Not even close. Take your car to a reputable LS1 tuner (you can find quite a few on here) and let them do the tuning.
Old Oct 31, 2008 | 10:14 AM
00TurboTA's Avatar
Originally Posted by teke184
you can do either
x2 for cutting the wires that wont do anything. As for the operating condition of the car? that will change the computer will measure the after cat o2s and if it sees no signal or no change(o2's are constantly going rich-lean) then the computer is going to try and change everything on how the car is operating.
Old Oct 31, 2008 | 12:28 PM
SOMbitch's Avatar
No. The front o2's work with the PCM to adjust the the afr. They are the ones that have to function. The rear ones are an emmisions thing and just sense if the cats are functioning. Hence if you cut the wires the PCM gets no signal and assumes the cats are malfunctioning and triggers the SES light. Tune the rear ones out = no SES light.
Predators and handhelds are a total waste of $$ IMO. They are very limited in what they can actually do. Spend a little more for a dyno tune or find somebody close with HP tuners/EFI Live and get a street tune. It is usually a lot cheaper to get a DT "touched up" (by same tuner) when you add more mods too
Old Oct 31, 2008 | 01:02 PM
OMGls1jz's Avatar
alright thanks, so if i get an ORY and just eliminate my back o2 sensors without using a simulator will that work if i get a tune?
