Temp gauge
Old Jan 2, 2009 | 11:19 AM
richard david's Avatar
Default Temp gauge
I HAVE A2001 FIREBIRD THAT THE TEMP GAUGE is driving me crazy it might work for a day and sometimes a week but then it just go to 0. I changed sending unit, gauge cluster ,and pcm and it still does it what next
Old Jan 2, 2009 | 11:37 AM
Bad Blue WS6's Avatar
i want to say that the temp gauges in the 2000's on up are dummy gauges,,,meaning that it dosnt work worth a poo anyways..they just go up to a certain temp, and stay there,, your car would have already over heated by the time that gauge would respond. i know that dosnt answer your question at all, but you may consider installing an aftermarket type (ex. Autometer) until you can get your stocker back to "working" order.
Old Jan 2, 2009 | 11:48 AM
also when the gauge stops working the fans automaticly come on, someone told me it was the bcm but i dont want to just keep buying parts with out a second opion.
Old Jan 2, 2009 | 12:07 PM
2001NBMZ28's Avatar
Are you throwing any ECT codes? Sounds like you have an intermitent connector/wiring issue from the sensor connector to the PCM.
Old Jan 2, 2009 | 05:03 PM
yes it says low cooing temp
Old Jan 2, 2009 | 09:13 PM
2001NBMZ28's Avatar
Have the actual code?
Old Jan 3, 2009 | 07:28 AM
the_merv's Avatar
Veteran: Air Force
Sounds like the Signal going to the BCM for it is getting messed up.
