Big clutch issues??
Old Jan 6, 2009 | 07:57 PM
1Fr3shblkss's Avatar
Default Big clutch issues??
i was on free way in third getting on the gas brought the rpms up and when i went to shift to 4th clutch would not realease pedal was lose felt wierd and could not get it into any gear at all had to slow down in order for it to release and then it went in.. i also had a new factory clutch installed are they not setup for the camaro SS ??
Old Jan 6, 2009 | 08:15 PM
this is a brand new CLUTCH.. FROM THE DEALER.
Old Jan 6, 2009 | 08:27 PM
low12lightning's Avatar
Can you explain that a little more clearly?
Old Jan 6, 2009 | 08:31 PM
ctsv pulls up try to race drop to third gear. GO rpms in red push on clutch its at floor pedal is lose like the clutch is not releasing pull from third to go into fourth and i cant even get it in to another gear. try to go into another gear still wont go take my foot off clutch put it back on its likethe clutch is stuck to the floor the pedal moves but its lose until it gets close to floor but i cant shift into any gear until i slow down and i was trying hard. and it shouldnt take all that ..
Old Jan 6, 2009 | 09:19 PM
I'm not sure what you mean by "lose" like soft?? It sounds like you have a hydraulic issue. If the pedal gets soft, that mean you have air in the system. Not sure if the SS can really be bleed, or not. Some G.M. cars have to be "pumped up" via clutch pedal. Check master cylinder fluid level and color with clutch engaged and disengaged, try and "pump clutch to make pressure, bleed slave cylinder if problem stays. P.S. fluid in reservoir should be nearly clear, if not be concerned shop that did install did not properly bleed your clutch.
Old Jan 6, 2009 | 10:59 PM
IWGF's Avatar
Go to the manual tranny section in gen IV tech. sounds like you need to do the drill mod, flush your clutch fluid, and see where you're at then. If that fails, get an adj M/C, and if all else fails, a new slave cylinder and clutch. Camaros are well known for this problem.
Old Jan 6, 2009 | 11:03 PM
my correction wrong word.. excuse my ignorance LOOSE
Old Jan 6, 2009 | 11:19 PM
twitchtwice's Avatar
you need to do the drill mod, the cause of your problem is a lack of fluid in the lines in the transmission, search "drill mod" and you will understand.
Old Jan 7, 2009 | 01:24 AM
9000th01ss's Avatar
When? and who istalled it? SS, B4C, Z28 all the same.
Old Jan 7, 2009 | 02:33 AM
Chevy dealer a couple months ago i was having problems but i never really though of anything until now.
Old Jan 7, 2009 | 02:34 AM
what kind of clutch do they SS come with?? stock from factory.
Old Jan 7, 2009 | 08:32 AM
DCsLS1's Avatar
go to the manual transmision section and read the sticky about the drill mod and also the one on bleeding the clutch or just take it back to the dealer and have them fix it
Old Jan 7, 2009 | 10:50 AM
9000th01ss's Avatar
I don't think a dealer is going to do the drill mod.
That orifice that gets drilled is there to prevent fast shifting, they drill it, they think they're liable for any damages it causes.
Try a performance shop, preferably one that knows f bodies.
Old Jan 7, 2009 | 12:39 PM
DCsLS1's Avatar
i didnt mean for the dealer to do the drill mod lol i was saying if they messed somthing up then have them fix it
Old Jan 7, 2009 | 12:51 PM
9000th01ss's Avatar
Oh, right. lol
Actually he should do the drill mod, then take it to the dealer and have them bleed it.
Old Jan 7, 2009 | 01:09 PM
DCsLS1's Avatar
thats one of the best damn ideas ever!
