Rev Limiter
Old Feb 4, 2009 | 07:36 PM
ghardester's Avatar
Default Rev Limiter
I've been on here a long time, but this is probably a stupid question so I will start in the Newby section.
What is meant by 'hitting the rev limiter' ?
I have a 2002 WS6 Auto 4. The reason I ask is that sometimes I will reach the passing lane, say 50-60 miles per hour, and put the pedal to the floor and the car does what it should: down-shifts and goes like a raped ape.
But occasionally, I will put it to the floor and it is like the computer shuts off the gas/power for a minute and then it gradually comes back to full throttle.
I over maintain my car, so we aren't talking about plugged fuel filters, etc.
What is shutting off my power when I floor it at highway speed? It is kind of random but I want to know what you think.
Is this the 'rev limiter' or WTF?
Old Feb 4, 2009 | 08:26 PM
99345hp's Avatar
That isn't the rev limiter causing your problems. The rev limiter is to keep you from overrevving your motor and causing a disaster.
It sounds like an electrical malfunction causing your problem. Could be something in the transmission not allowing it to downshift, or you could also look at a possible intermittent throttle position sensor malfunction.
Old Feb 4, 2009 | 09:17 PM
nemss1's Avatar
could be a fuel delivery issue, vacuum leak, misfire, ignition probs, bad tune
could be any of those possibilities
vacuum leak would be noticeable how the car idles tho
Old Feb 4, 2009 | 09:27 PM
Dan Stewart's Avatar
You probably need to have a scan performed while driving it. It could be pulling timing due to knock or pulling fuel because of Cat protection. Or some other perceived problem the computer sees.
Old Feb 5, 2009 | 06:09 PM
ghardester's Avatar
Thanks, I'm kind of leaning toward it being a throttle position sensor issue. It really does behave like the PCM is not wanting for full power to kick in as some sort of fail-safe/safety issue. No missing or other performance issues. Car only has 45,000 miles and filters, plugs, fluids all get changed regularly. If you keep the pedal down, after a second the engine excellerates smoothly up the full speed instead of kicking it all in at once. Like some sensor or computer has decided I can't have it all. Now that you mention the tranny, it's not kicking down a gear when this happens. I think I'll service the tranny and check the trottle sensors.
Rarely happens, and only when I go to the floor.
Old Feb 5, 2009 | 09:06 PM
sherm6998's Avatar
Try manually downshifting to 3rd then stand on it and see if it does the same thing. You can see alot of info with a tech II at a gm dealership. Ususally $45 for a half our of diagnosing.
Old Feb 5, 2009 | 09:13 PM
blue98Z's Avatar
What about traction control. It will also do that and don't think it won't spin at 50mph cause mine sure as hell doesn't have a problem doing it and that was before the cam swap. It'll make the pedal feel hard and the car will feel hesitant. Look at your dash next time to make sure your low trac light isn't on. Could be that simple.
Old Feb 7, 2009 | 03:16 PM
ghardester's Avatar
I have installed the SLP traction control reverse, which keeps it always turned off unless I hit the switch to turn it on. And I am aware of how the pedal kicks back when TCS activates. But thank you for the input.
