Firewall question
Old Feb 7, 2009 | 05:36 PM
z28_YOU_HO's Avatar
Default Firewall question
Where on the firewall can i run my nitrous line through? Ive looked and cant find anything
Am i just retarted?
Old Feb 7, 2009 | 06:17 PM
nemss1's Avatar
grommets behind PCM or big wiring bundle on drivers side
Old Feb 7, 2009 | 07:08 PM
BobDoLe's Avatar
^^ yeah
try removing the nuts holding the pcm down (passenger side), then move the pcm over a little and feel back there. you'll feel a good sized grommet with some wires coming through.
from the inside of the car, remove the plastic piece under the glove box as well as the trim on the right side. while kneeling on the ground next to the passenger seat - reach up along the right side of the firewall and you'll feel that grommet.
just make sure to seal it off or keep the grommet there or you'll get some extra noise coming in down there. i got so much **** going through that grommet, all i use is wire loom to seal it now (not recommended).
Old Feb 8, 2009 | 08:54 AM
RedRallyeZ's Avatar
Originally Posted by BobDoLe
^^ yeah
thats where i ran my amp cables. and DO make sure to seal it off, like he said, can be loud
Old Feb 8, 2009 | 09:14 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
on the gromment behind the PCM
Old Feb 8, 2009 | 11:40 AM
casca2001's Avatar
If i remember correctly you could fit a 1/2'' line through there with no problems, also a perfect spot to run wires for a shift light, and make sure to go through the grommet and not just leave it out, otherwise the metal on the firewall has a tendancy to fray things
