Foam on bottom of ls6 intake?
Old May 9, 2009 | 09:40 PM
syclone74's Avatar
Default Foam on bottom of ls6 intake?
Is the foam needed that goes on the bottom of the LS6 intake? I just put new gaskets on the intake and the kit was missing the foam, and I threw the old foam away. Do I need this?
Old May 10, 2009 | 02:58 AM
brianfromhawaii's Avatar
negative.
Old May 10, 2009 | 09:54 AM
syclone74's Avatar
Thanks
Old May 10, 2009 | 09:57 AM
CranMaro99's Avatar
It is indeed needed! I know so many people that removed the foam and then had to chase knock sensor codes forever, until they re-installed the foam. Good luck.
Old May 10, 2009 | 10:07 AM
slayerized6's Avatar
pick up a strip of 1/4in window weatherstripping and seal off the front and back gap's at the intake and valley cover.
when i swapped my intake, i was astonished how much dirt got under there; i had to use a vacuum to remove all that crap
Old May 10, 2009 | 08:12 PM
syclone74's Avatar
Okay thanks for the advice guys i will get something to put on the intake.
Old May 11, 2009 | 12:21 AM
01ssreda4's Avatar
experienced exactly this with a buddys car. go to your local fabric store and get a little bit of 1/2 to 3/4 thick foam. it will only be a couple bucks. it will work great.
