CAM and A/C
Old May 15, 2009 | 06:03 PM
LS1TAUTO's Avatar
Default CAM and A/C
if i were to get cam would the ac blow as cold....wouldnt it f up the idle since its already runin a low idle.....cam guys let me kno wats up
Old May 15, 2009 | 07:54 PM
SOMbitch's Avatar
A bigger cam actually requires more idle so no negative effect. Cam in sg idles 900. Plus you can always get a OD AC pulley if it becomes an issue....
Old May 15, 2009 | 08:17 PM
Sharpe's Avatar
If you have to be disconect the AC at some point during the swap, a lot of people say it is never the same afterwards. Mine blows cold as ever, but I had EPP do all my work. Something to consider.
Old May 15, 2009 | 08:58 PM
BriancWS6's Avatar
The A/C will still work just fine.
I've done multiple cam installs, had heads off, etc, and I have my entire engine, trans, and K member out of the car at the moment, and I've NEVER had to disconnect anything to do with the A/C.
Old May 15, 2009 | 10:15 PM
NVR_SPDS's Avatar
My wifes car is a 231/237 (598/595) and her AC is nice and cold.
Mine is a 234/230(i believe), but dont remember ever using the AC.
Old May 18, 2009 | 12:09 AM
TXws6's Avatar
mine blows just fine with a 230/236, What size cam are you looking into?
Old May 19, 2009 | 03:49 PM
LS1TAUTO's Avatar
just lookin for a mild cam not to big not to small just lookin for a nice lope
Old May 19, 2009 | 08:22 PM
4WOFURY's Avatar
My car has a 232/240 .598/.608 110, and the ac blows ice cold. Only down side is that if you turn the ac on at idle, the car gets a little erratic for a moment and tries to die. No problem other than that.
