need help
Old Jun 28, 2009 | 03:18 PM
VTEC-THIS's Avatar
Default need help
ok 99z28 cam and bolt ons stock heads. I broke a axle at the track ,car sat up for about 3 weeks. Ever since putting the rear end back together the car is way down on power and throttle response. but runs perfectly fine does not miss or skip. just kinda weak, seems like it went from 380whp to like 300whp feels like a stock ls1. And it is absolutly driving me mad. Took it to 2 shops and they drove it and looked at me like i was stupid. It seems like it might have a little valve train noise under load at certain rpms but its hard to tell. I took of the valve covers and looked at everything seems ok. was thinking i might have a bad lifter but am not sure of the symptoms of this in these cars Any thoughts would be great..
BTW it has nothing to do with the rear end ,that i am sure of.
Old Jun 28, 2009 | 07:49 PM
mook99ta's Avatar
If you had a bad lifter you would hear it. Are you absolutely sure its not your rear end. Try and do a burn out and see if both tires spin you may have chunked your differental. What did you replace when you rebuilt your axle?
Old Jun 29, 2009 | 12:52 AM
Xtreme864's Avatar
If you replaced the whole rear, you might have had a larger gear ratio in your old rear end than in the new one. Just a theory.
Old Jul 1, 2009 | 09:24 PM
VTEC-THIS's Avatar
Default rear
i built the rear twice because i thought that it might be the problem . moser axles, new richmand 4.10 gear set(same as before) all new bearings and it is spot on . the rear is not the problem . I'm an industrial mechanic so i've got a good hold on working on stuff. but i can't figure this one out . I think i hear some valve train noise but it does not seem loud enough to me to be a completly bad lifter. maybe one that will not stay pumped up all the time but hell IDK. the car has a cam(don't know what it is was in it when i got it but it lopes pretty good) long tubes,ory.slp lid , ported throttle body, 4.10s , and a ram hd clutch, still has the stock intake. I've been wanting to get a intake and take the car and have it tuned. But i've got to get it running right again before i throw money at it... AND if i take these heads off to change the lifters THEY AINT GOING BACK ON IT . If you know what i mean.
