Transmission problem???
Stop driving the car is you can, and if you must drive it, shift into neutral at stops and let the clutch out. Because every time you stop and hold the clutch pedal in, you're frying the clutch disc. And each time you try and shift gears with the engine running, you're putting excessive wear on the transmission internals.
Definitely get the problem adress ASAP before it causes more damage.
