problems with ported throttle body
Old Sep 30, 2009 | 11:13 PM
pheer's Avatar
Default problems with ported throttle body
bought a throttle body from a member here and went to install it but the throttle cable seems to have too much slack, is there a way to tighten it?
EDIT: did a search and found out how to tighten it, but it isn't enough, is there anything else i can do besides just that little adjuster spring?
EDIT EDIT: turns out i received a 98-99 TB when i obviously need a 2002.... anyways, i swapped the cam? and lobe? into the technically older TB and it all works fine now...
Old Oct 1, 2009 | 05:19 PM
StuntmanMike's Avatar
How did this work out? I read somewhere the new cam lobe is designed for slower throttle response than the older setup. How do you like the feel of the earlier cam lobe? Better throttle response?
Old Oct 2, 2009 | 12:23 AM
JonCR96Z's Avatar
It sounds like he didn't like it since it had too much slack.
The older throttle cams are smaller and round. Giving pretty much a 1:1 pedal to thorttle ratio. The newer ones are weird shaped so that they start off not opening as much in relation to the pedal then gradually ramp up. Keeps them from being as touchy right off idle and in low throttle situations.
