Help!!!
-Dave
Have you logged the A/F ratio? Sounds like it could be a fuel pump issue. Adding timing wouldnt change where the fuel pump maxes out. Could also... however unlikely be a tune/computer issue. I have one sitting on my desk that would (for no reason at all) think it had knock and would retard at a certain KPA. Only happen when that particular KPA was reached. So funky things do happen w/ comps. Are the O2's fluctuationg quickly?
What mods do you have? It could be anything from a maf issue, to a map sensor, to the tune, to an intake leak (un-metered air getting in), fuel pump, O2 sensor... Did you check the wiring on the passanger side to see if anything is getting cooked? (follow it down the engine bay from the top of the motor down past the headers.)
-Dave
