Cooling system
agreed. That thermo is a waste of $$. I had one when I purchased the car and swapped it out for a stock 195* thermo. I have read numerous things on this and I noticed that the car definately runs better when it gets up to full operating temp rather than having that thermo. Spend your money on something better.
mark jr.
mark jr.
a lower temp thermostat will keep the engine running cooler any time you are moving. the only time the fans come into play is when sitting still with no airflow over the radiator.
and even then, the stock setting will (should) keep the engine perfectly safe. you just may not get as good of performance due to the much higher heat.
i ran a lower stat for years, on 3 different Fbodies, without ever tuning the fans. every time i drove i could see the cooler temps and benefited (albeit small) from it. later on i installed a fan switch to allow me to cool the car down as needed when stuck in traffic or sitting in the staging lanes.
i know from watching the scanner that with a 160* stat my car would not cool down past 172-173* even with the fan switch on HIGH. this was in a mild florida temperature.
a cooler running engine can allow for a more aggressive tune, which can yield more power.
Ideally, you want a nice warm combustion chamber and the coldest possibile air charge for best overall engine performance. This is true for any engine, not just an LS1.
