fluids question
Old Jan 21, 2010 | 11:20 PM
jconk's Avatar
Default fluids question
flushing out the cooling system after a head gasket went bad. My question is would it be ok to use only distilled water in the system to work out the crap before i return to the DEXCOOL fluids.
Old Jan 21, 2010 | 11:49 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Distilled water is the ONLY water you should ever put in the system.
And yes, it's fine to run straight water (distilled) so long as you're in a climate where it doesn't get below freezing.
Old Jan 24, 2010 | 06:12 AM
the_merv's Avatar
I'm using the good ole Garden Hose water without issues..
Old Jan 24, 2010 | 11:59 AM
brandon9598's Avatar
DO NOT use Dex coolant! It eats away at seals and gaskets.
Old Jan 24, 2010 | 01:48 PM
RPM WS6's Avatar
It will eat away nothing more than any other type of coolant so long as it's changed regularly.
