Lower end rebuild
I put the motor in my 944 and start it up, it smokes a little. I figured it just had unburnt deposits from sitting. Then it kept smoking and smoking, buring oil.
I have not done a compression test do to the temprature dropping and the snow falling. But it seems to me like the rings are stuck, or worse case broken.
I need to know if I can just replace the rings with some homing to the cylinders or do I have to get the crank balanced and all the stuff?
After the weather straightens out, do a compression test and leak down. That will tell you what is up.
