Dead spot help
Old Feb 23, 2010 | 07:36 PM
Wantin-somthin-more's Avatar
Default Dead spot help
Hey guys i might have messed up. i did the free ram air mod with at home port and polish MAF* and i have a dead spot at 4000 to 5500 rpms. It may have been there before but i just noticed it a lil while ago. i was thinking air/fuel ratio or maybe a simple tune up would do it. Any body have ne ideas?
Old Feb 23, 2010 | 08:26 PM
Juicy J's Avatar
Honestly, you might just be getting used to the car. Did you notice this immediately after you polished the MAF? Are you throwing any codes? I guess you could have messed something up.
But if you are asking if something as simple as a ported TB, and polished MAF would constitute a tune, the short answer is no. The only reason your car should be running different is if you hurt something during the process of modifying the MAF/TB.
Old Feb 23, 2010 | 09:25 PM
no codes no problem other then dead spot. I thought that i was lean and it was causeing a dead spot. did your car have a dead spot stock?
Old Feb 23, 2010 | 09:29 PM
Z28_LT1's Avatar
define "dead spot". Do you mean you're at WOT and then when you hit the top it feels like you let your foot completely off the gas?
Old Feb 23, 2010 | 09:39 PM
Searching4Sierra's Avatar
try some MAF cleaner
Old Feb 23, 2010 | 09:47 PM
the dead spot im refering to is im at wide open throttle and it feels like i let go of the gas about half way then kicks back from 5500 to red line (which isnt very much) well i bought a 100 shot NOS kit and i dont wanna run it until i get it fixed if it is too lean it could cause problems. just dont wanna get ahead of myself and mess something up...
Old Feb 23, 2010 | 09:48 PM
MAF cleaner? oriellys sell that?
Old Feb 23, 2010 | 09:50 PM
yeah you should be able to find it at those places. CRC mass air flow sensor cleaner. Its a cheap place to start instead of doing a whole tune-up
Old Feb 23, 2010 | 09:52 PM
my car had a dead spot, i pulled the MAF and the actual sensors on it were completely black. after i cleaned it the car ran 100 times better
Old Feb 23, 2010 | 09:53 PM
WOW when i port and polished the MAF i noticed that the resister looking things were a little bit black thanks alot.
Z28_LT1's Avatar
my lt1 was doing the same thing when I had it. it was running hella lean up top. My advice to you would be not to run it that hard untill you figure out what is wrong. Changing a fuel filter will help, it helped me at least. U might want to look into that....
Old Feb 23, 2010 | 09:56 PM
ya well i have a fuel filter plugs talor 10.4 wires and nos to put on this weekend but working 60hrs a week and going to school full time i only get a limited time to work on the car just trying to get the best advice what to do.
Old Feb 23, 2010 | 10:04 PM
yeah just be careful when you clean it, use the cleaner and a q-tip. dont touch the wires with your hands
Old Feb 23, 2010 | 10:12 PM
Hey guys thanks alot for the info you guys make this cite great. ill try the cleaner.
Old Feb 23, 2010 | 10:27 PM
Juicy J's Avatar
I just assumed that if you ported your MAF, you would have saw all the sut (spelling?). You can buy the MAF cleaner from any automotive store. You just spray it on, and let it evaporate. You could also use q-tips to assure everything is clean. Don't apply pressure, but gently slide the q tip across the wires like mentioned above.
If the dead spot is super noticeable, then you might really be having problems How many miles are on the car, and have you done a tune up? The fuel filter would be a good idea to look at, as mentioned above. You might check your fuel pressure. If you can afford a wideband O2, it would be a good investment. I think it's an important item to have when running N2O.
If you have a dyno available in your area, it might be a good idea to throw the car on it. They should have a wideband to monitor your car on the dyno. A dyno can be a great diagnostic tool to figure out if you are actually having a problem, and see how severe your problem might be.
I would definitely recommend staying away from the nitrous until you get everything figured out. Running a power adder on an already handicapped car is just asking for trouble.
Good luck, and let us know if you figure anything out. If you find anything else out that might help us diagnose your problem, be sure to post it up.
Old Feb 26, 2010 | 08:39 AM
Update. Well i used the cleaner and it helped but theb i changed the fuel filter. It was so clogged up little chunks were coming out and i couldn't even pass ne air through it. Much better thanks for the help.
Old Feb 26, 2010 | 11:53 AM
glad to hear youre back on the road
Old Feb 26, 2010 | 11:59 AM
01ssreda4's Avatar
good job
Old Feb 27, 2010 | 11:44 PM
update man if you guys havent tried the taylor 10.4 wires you guys need to try a set. throttle response is a lot better and a little gain in acceleration.
Old Feb 28, 2010 | 12:09 AM
yeah i think im gonna wait till i do headers to change my plugs and wires
