All sorts of problems!!
Old Jun 23, 2010 | 09:38 AM
yamaharacer114's Avatar
Default All sorts of problems!!
Ok to start when the engine is started the car sounds like a damn sewing machine then starts to quiet down as it gets heated up, i have attributed this to the lifters (For now) but the valvetrain noise is getting worse. My POA is to buy some ls7 lifters and swap those with the old ones, and put in some 7.425 pushrods. The car right now has a pretty rough idle and I will get a random multiple misfire code about once every other week. Any idea's on if i have the proper diagnosis. The car also has 93k on it, so that needs to be factored into the overall equation as well.
Old Jun 23, 2010 | 10:34 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Have you scanned to see if the misfires are specific to certain cylinders, or is it just a random misfire? (not just codes, but a detailed scanner that will show cylinder specific misfire counts)
Your cam will cause random misfires, especially at idle. The tune may also need to be looked at.
If the lifters are failing, that would certainly aggravate both misfires and valvetrain noise.
I would suggest to go over the usual basics first (if you haven't already), like regular maintenance for spark and air/fuel delivery.
Old Jun 23, 2010 | 11:07 AM
i haven't checked with a specific scanner yet to see if the miss fire is cylinder specific. Have gone through regular maintenance just to make sure it wasn't something fairly simple, and came up with nothing. I haven't had a tune on the car since i installed the cam either. I also have a LOUD "chatter" coming from the motor when the engine is experiencing a heavy load such as loading up the motor at 35mph in 5th gear, I get this noise that i can only describe to you as what sounds like the lifters bouncing off the cam or some kind of valve chatter.
Old Jun 23, 2010 | 12:33 PM
RPM WS6's Avatar
That's a fairly long duration cam for a stock tune. I would not be surprised to see several idle issues and low rpm driveability concerns with that much cam and a stock tune.
