Is this normal?
Old Sep 3, 2010 | 08:24 AM
Tyler_PinkertonZ28's Avatar
Default Is this normal?
This morning was the first cool morning we have had since I got my car. Is it normal for the car to take much longer to get to operating temperature when it is cold outside? Normally I let the car warm up for about 3-5 min and then drive it slowly out of my neighborhood and it hits operating temp as I pull out on the main road. This morning I had to drive almost the entire way to work (5 or 6 miles) before it ever hit operating temp. I did have the heat on, but would that make that much difference?
Old Sep 3, 2010 | 11:09 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Yes.
Yes, this will also extend warm up time a bit.
As long as the engine still reaches normal operating temp, then you are fine. If not, then you're likely looking at a t-stat that is stuck open.
PS. I see that you have a '98. '98s are the only year to get a super sensitive temp gage that shows small changes in operating temps. As long as the needle eventually rises near to the first notch, I would not be worried.
Old Sep 3, 2010 | 11:13 AM
Ok, i just wanted to make sure. Thanks.
Old Sep 3, 2010 | 11:17 AM
Jonnie Bravo's Avatar
Yes having the heat on draws more cool air from the outside through the motor.
Old Sep 3, 2010 | 12:32 PM
omarrakeen's Avatar
hell yes its normal.
Old Sep 3, 2010 | 12:38 PM
Haha, thanks for the help.
