engine problem, quick questions
for the question part if i pull the engine completly im gunna atleast put a cam in it if not rebuild teh whole thing, main question is if i rebuild it, new pistons, rings, valves etc what ever, i knwo theres a brake in time, but with a cam u have to it tuned right away but it requires dyno pulls, what do u do? do u just let it break in idling or get it semi tuned drive till it breaks in then full tune or what? thanks guys
Unless you are really leaned out for some crazy reason then you should be just fine. Just try and keep a load on it and fluctuate the idle fairly often with it above 1700 or so. Dont go crazy revving it either. You see alot of high perf engine builders basically going WOT on new builds within the first few runs, but I just dont see that as being good for the average joe building an engine that is for mostly normal use... I know of a guy who will practically let the engine heat to operating temp while under light load, adn once its there its basically a build up to WOT runs... He makes some crazy stuff, but I wouldnt want my street car done like that haha.
When building the yodas we always went by the "break it in like it will be driven" rule. If its a DD and not a racecar, it doesnt need to be broken in that way simply b/c the rings are not going to need to seat that hard immediately and typically wont be under that kind of stress for the majority of the time.
Just take her easy and keep the idle inconsistant and fairly smooth and you should be golden. IF you have the opportunity and setup to get it on its wheels first thing, then I would wait till it hits operating temp and then drive it up and down the road and go through the gears. Try and maintain a progressively increasing load on it for a while. This is how I'd do it if it were my car. Its how I did my formula M6 and my other personal car...
Cost is going to be how much you would like to spend, but I guarantee if you get new pistons and do a full rebuild using your rods and crank, you will be looking at at least a 1500 in parts considering you do the cam right and get good parts, and get upgraded pistons... TSP's cam kits are from 6-700$, and a good set of pistons will be the same, and then you have the gasket kit, etc etc... So the price is really what you want out of it.
I would account for at least 3 weeks as well if it were me(im quite limited on time to work at home now so it goes fairly slow) even if you have most of the parts from the get go... Im sure there are guys who can do these engines in a weekend, but I wouldnt count on it for the first time... Prepare for broken minor parts and tough situations when doing the whole job. Take your time, be thorough, and DO IT RIGHT THE FIRST TIME!!! Oh, and if youre clutch is even close to being worn out i'd go ahead and knock her out. If you have the extra cash get a good one like the Textralia OZ700 or something so you dont have to worry about that new power killing a stocker soon...
Oh, and if you dont have an aftermarket intake, i'd go there as well if you can afford it just to save you the hassle...
Just my opinions here, and nothing more. Im not claiming expertise or anything, just a bit of experience with a lot of trial and error
There are many guys here who can give you much better approximations on costs and time as well. I was just estimating...
