LS1/LS6 intake diff?
Make sure you take care of the coolant lines. You can either buy them off the internet or you can just do what I did and just take your LS6 manifold and, using pliers, snap the ridges off. That is PLENTY to clear the lines, but for the sake of cleanliness, I followed up with sandpaper. While you're in there, make sure your knock sensors aren't corroded, if so, go ahead and replace them. Use a shop-vac to make sure there is no moisture in the holes, put the rubber grommets back on and take some high-temp RTV and put a nice bead around the grommets and seal it with your finger. I know it sounds excessive, but I have had to change my front knock sensor twice due to moisture getting in somehow. After sealing it up, it does fine. I'm sure it has to do with me living on the water though... Hope this helps!
Kyle
P.S.: Do NOT tilt the manifold back when removing it! You will snap the oil pressure sensor!! Lift up and out!
hi, try these part numbers:
