alternator replacement question
Sounds like you just swapped the output posts from one alternator to the next. That should be fine, as long as it's installed tight. If it was rust and corrosion that caused the nut to seize though, conductivity might not be perfect. But if everything seems to charge fine then I wouldn't be too worried about it.
