What To Mod Next
Next do the Heads and cam (that you decided on when you ordered the comverter). Now you have lots of HP and are making the most of your entire car.
Finally do the 12 bolt and tranny. The 10 bolt will hold out for quite a long time behind an auto (as long as you don't run slicks) and the stock tranny will take quite a bit. When the tranny does go, just rip it out and replace it with a built unit.
Up front I think your crazy to say you want 600+ HP and have NO worrys about lifespan (just won't happen). Even the best parts out there will eventually have problems with 550+ rwhp being dumped through them on a regular bassis.
For starters they are 508 CI (basically 1 HP per CI). Then you move to they are a manual trans (the T56 seems to take A LOT of beating and the Viper box is a HEAVY DUITY version). Finally reach the rearend which is basically a Dana 44 and you understand why they can take 550HP day in and day out.
You can build a car that will take 600+ HP for a long time but all I'm saying is saying "I want tons of HP and no problems" is like people who say "I want a BIG cam but I want it idle on a stock tune".......
Just kidding man. Happens to the best of us. I go back and forth like that too when I'm talking about mods and my dilemas. Good luck with your project. Tear it up!
I still say your best bet is to figure out what size cam you WANT and go ahead and by a converter that will work with that. It might be a little much for your stock setup but it sets you up. Also get headers (I REALLY REALLY like my Hooker LTs though have them coated by JetHot) so you have the exhaust flow to support whatever cam you do in the future. You might even look into a set of heavy duity gears (I like my Richmonds), an Auborn Pro Posi , and a TA gurdle to beef up the 10 bolt rearend for a while (not to mention improve performance).
