Security System Elimination???
Old Jul 28, 2011 | 07:56 AM
randytj's Avatar
Default Security System Elimination???
I keep having problems with my 1998 SS.
Every so often when I try to start the car nothing happens.....I need to let it set and reset the Vats security system.
I would like to get rid of it........
Is here a way to completely eliminate or bypass the system?
I already did the key bypass with resisters but must be having problems other places in the security system.
Old Jul 28, 2011 | 08:11 AM
BlackScreaminMachine's Avatar
Internet Mechanic
You need to have it tuned out, very common with LSx swaps into other vehicles. Go to the PCM/Tuning Section, a sponsor there can help.
Old Jul 28, 2011 | 01:45 PM
2001NBMZ28's Avatar
Is the security light coming on? Shouldn't if VATS was bypassed correctly. PCM tune alone won't do it - the BCM enables the crank circuit to the starter and simultaneously sends a signal to the PCM fuel enable circuit. If the light isn't coming on something else is happening.
Old Jul 28, 2011 | 03:58 PM
randytj's Avatar
The security light comes on if the car does not start.......the car will start for me about 3 out of 5 times I go to use it, when it does start - no light.
Old Jul 28, 2011 | 05:22 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You can hardwire around it, but honestly it's much easier to just have it tuned out!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 28, 2011 | 05:49 PM
2001NBMZ28's Avatar
You saying you can tune out VATS only in the PCM on a stock car and it will completely alleviate his issue? Not trying to argue, but the PCM doesn't read the key pelet value, the BCM does right?
Old Jul 31, 2011 | 06:05 PM
Sorry I wasn't clear. Vats is in the PCM, and is easily tuned out. The common security issue is through the BCM and can be wired around. Sorry I was unclear there.
