Tail lights
Old Dec 18, 2011 | 12:57 PM
ballistikball's Avatar
Default Tail lights
I'm experiencing a problem with the passenger side tail lights being brighter than the drivers side. I've replaced all bulbs in both tail lights.
Thanks for the help.
Old Dec 18, 2011 | 01:04 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Is this on a Trans Am/Firebird? I'm assuming so, because I've never seen this issue on a Camaro.
If you are using the same bulb type/number in all sockets, then the issue is likely due to a lens problem. Sometimes they leak moisture, which darkens the lens, and over time will deteriorate the internal reflector making them even more dim.
Old Dec 18, 2011 | 01:12 PM
It's on an 02 Trans Am WS6. Didn't notice any moisture in the lights, but I'm not the original owner. Thanks.
