Pulley Puller help!!
Old Aug 21, 2012 | 01:17 PM
USMC5811's Avatar
Default Pulley Puller help!!
Any suggestions on getting off the UD pulley? The 3 jaw puller sucks *** and isnt working....
Old Aug 21, 2012 | 01:33 PM
blk/slvr02ss's Avatar
I have the right one and you should be able to get one from your local parts store to rent but from what i remember a after market UD Pulley has 3 threaded holes in it like a Gen 1 SBC and you can use that puller also.
Old Aug 21, 2012 | 01:45 PM
johnLs1camaro's Avatar
i have a cheap *** harbor freight 3 jaw puller and works fine.
Old Aug 21, 2012 | 01:53 PM
NemeSS's Avatar
^+1
I have that 12$ puller. 3jaw. Literally ive lost count on how many pullies ive pulled off ls motors. It only works on truck and ls cars except the vettes. I got a smaller one i made from 2 others.
Old Aug 21, 2012 | 02:09 PM
777's Avatar
777
Some underdrive pulley's have to use a different type of puller. Not a 3-jaw, but one with the threaded rods like blk/slvr02ss said
Old Aug 21, 2012 | 02:12 PM
jc98ss's Avatar
none of the regular pullers would fit the threaded holes in my March UD......i had to buy a large 3 jaw from TSC
Old Aug 21, 2012 | 04:08 PM
Marios_98z's Avatar
So getting it off is just as bad as putting it back on!
Old Aug 21, 2012 | 04:23 PM
jc98ss's Avatar
pretty much, the pulley was the most time consuming thing i had to do when the cam went in........well, besides the big-gay valve springs
Old Aug 22, 2012 | 08:37 AM
USMC5811's Avatar
my aftermarket pulley doesnt have bolt holes so i cant use that type of puller. the big grooves on the pulley where the 3 pullers would grab onto are not flat, they are slanted so the teeth slip right off. the only way to grab it is from the very back up by the timing cover, but when that happens the 3 pullers always end up hitting the front lip of the pulley and therefore pry the teeth off of the back when i start tightening it down.....
Old Aug 22, 2012 | 09:18 AM
would grinding the teeth on the puller make it fit better? you could put a angle on the teeth which would fit the pulley better?
Old Aug 22, 2012 | 12:02 PM
I Got the right tool to put it back on also i bought from a guy making them on here !!!
Old Aug 22, 2012 | 04:41 PM
USMC5811's Avatar
might give that a try
Old Aug 22, 2012 | 04:46 PM
I Got the right one from Tool Wharehouse on line for like $28.
