Ls-?
The engine was supposed to have suffered cam bearing damage. Upon dis-assembly no bearing damage was found. In fact the the internals appeared as new with excellant cross hatching in all cylinders, cam bearings look almost new, no visible cam wear......but, valve seals in the middle two cylinders passenger side had failed...fouling the plugs causing the rough running condition complained about by the owner. It was swapped under warrenty by GM.
I don't need more power than its got stock for this app...so, I'm thinking about putting all back together sans the vvt, with an MSD ingnition, stock coils, dual plane intake and a 750 carb..?
Does this sound reansonable..? The engine has 100K miles on it....maybe new valve springs..?
Will the orig cam shaft with non vvt phaser gear work..? I just don't know enough to answer these questions myself.
Bob S
Bob S
